Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2013 Basin fails to install "SQL 2008 fails"
3 REPLIES 3
n2ospeed
340 Views, 3 Replies
Anyone having issues with Vault Basic 2013 not installing due to SQL issues.  I've removed the previous version of Vault 2011 and also gone so far as to remove SQL 2005 and the database in an attempt to get it to work with no luck.  I've uninstalled all SQL servers and rebooted several times through the course of attempts.
I'm at a standstill and out of ideas.  Any help would be appreciated.
3 REPLIES 3
JamesMcMullen
in reply to: n2ospeed
What is the error that you are seeing?  It sounds like some of the database files didn't get fully removed during the uninstall process but am not 100% sure.
-Jim
James McMullen
Principal SQA Eng.
n2ospeed
in reply to: JamesMcMullen
I've attached screenshots from the fail error on the Vault installer and the log file.
JamesMcMullen
Trying the following:
http://crackingthevault.typepad.com/crackingthevault/2010/03/how-to-troubleshoot-autodeskvault-sql-i...
The problem is the 1603 is a pretty generic issue.  Here is another thread on the newsgroup that had a similar issue to what it appears you are doing:  http://forums.autodesk.com/t5/Autodesk-Vault/1603-Error/td-p/3264344
-Jim
James McMullen
Principal SQA Eng.
