Vault General
Active Contributor
coemter
Message 1 of 6 (409 Views)
Vault 2012 permissions
409 Views, 5 Replies
07-19-2011 12:09 AM
We switch to Vault 2012 recently. Some users complains some problems when renaming and moving and i was trying to reproduce that. So i notice that my users now can remove files and folders. If i remember well before (since Vault 2007) my users should not delete files and folders in anyway (they can move into a special folder that the admin will remove).
How can i configure permissions so that users may do most things, but not removing in any way ?
Valued Mentor
jclaidler
Message 2 of 6 (388 Views)
Re: Vault 2012 permissions
07-19-2011 05:55 AM in reply to: coemter
Assign them to 'document editor 1'.
_______________________________________________________________
ITO - Application Management
AutoCAD 2014 | Inventor Professional 2014 | Vault Professional 2014
Active Contributor
coemter
Message 3 of 6 (369 Views)
07-19-2011 11:15 PM in reply to: jclaidler
So they cannot rename files...
Employee
yuhui.zhang
Message 4 of 6 (363 Views)
07-20-2011 02:18 AM in reply to: coemter
correct, the permission of rename, move sharing same user role with permission 'delete conditional' - Document Editor (Level2). For this case, if you works with Vault Workgroup edtion (or above), Access control list (ACL) of folder security or State  security may help to match the requirement besides basic role based security. For Vault 2012, no more option to configure.
Fay Zhang
Software QA Engineer
Data Management
Be sure to check out the Vault Help Wiki!
Active Contributor
coemter
Message 5 of 6 (359 Views)
07-20-2011 02:59 AM in reply to: yuhui.zhang
So "standard" Vault server gives me 2(!) sets of permissions combination only. Come on guys, even this is the entry edition, it is server software. Now i can have up to 10GB database (and many many files) and my end-users may delete all with one click ...
Valued Mentor
jclaidler
Message 6 of 6 (351 Views)
07-20-2011 04:54 AM in reply to: coemter
If you use 'document editor 1' for the permissions, then the user can't delete files.
You can also use 'folder level security' to limiit the deleting of files, unless you are using the basic Vault version.
Folder Level Security you can assign the use as 'read-only', 'full control' or 'no access'.
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
