You can download Vault 2012 Update 1 from here:-
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=17994779&siteID=123112&linkID=9261341
Solved by MattH_Work. Go to Solution.
Trying to install Update 1 and keep getting the following error
at this point in the install
Any ideas
Cheers
MattH
Can you please install all the Windows Updates and then try the installation of Vault Update 1? Restart the machine once you are done with the Windows update before applying the Vault Update 1.
Windows updates have all been installed (except SQL 2008 SP3 which I presume is not supported)
AV is off & UAC is disabled
Cheers
Matt
Im not sure if you are still having problems Matt but please start a new thread if you are.
we are having problem with Vault2012 Update1 too...Error1328.
The instalation on the server was successful but instalation on the workstation(client) had this error.
Windows updates have all been installed, antivirus is off and UAC is disabled.
Is there any possibility to find out solution?
Thank you for your reply..asap...
Tomas
