I would like to set up a test installation of Vault Pro 2012 Server and client on my laptop. I have installed Vault Pro Server 2012 Pro (for which I have a product key) and 2012 Vault Pro client.
I have pointed the LICPATH.LIC to my laptop's IP address and MAC address. and I have disabled IPV6.
I also created an environment variable ADSKFLEX_LICENSE_FILE and set the vaule to be the laptop hostname.
I am getting the message "Unable to acquire license" when I try to log in to the Vault.
Is there anything else that might be causing this error?
Solved by Andy.Spivey. Go to Solution.
Solved by DarrenP. Go to Solution.
Is the FlexNET service configured to host your 2012 VP licese?
Is the service started?
Does a status inquery show that liceses are available?
did you generate a license file for your laptop?
DarrenP
Pardon my ignorance but I had not carried out this step. Will do so when I get back to the office, thanks
Tom
I have run a ststus enquiry and it shows various license servers, but I don't see my local one which I know has one license available. Why would it not be showing? Is this a permissions issue?
tmccar, I did not follow your last update.
So you perform the Enquery from LMTOOLS (per image below) and the licenses are not listed?
So to clarify, there are 47 vault licenses hosted on your machine, 7 folks are able to connect and obtain a license from other machine. The only machine that cannot obtain a license is the maching hosting FlexNET itself?
Can you remove the environmental variable that was created above and change the LICPATH.LIC to read:
SERVER 127.0.0.1 000000000000
USE_SERVER
If you change the LICPATH.LIC then to point to the IPv4 address of the license server and not your machine?
I was under the impression that you were running the 2012 client, 2012 server, and license server with 2012 licenses on your machine.
No, I have a standalone Vault Server 2012 installation (I have a product key for it). When i install the server on my laptop, it prompts for either the product key or the license server. I tried it initially with the product key, but I got the error.
Then I decided to try it with the license server option. Now our reseller has told us that there is a Vault license on a local server that is not in use. I want to use this license if possible. But I don't have permissions to the server (I can't map a drive to any of its shares). Could this be why it's not acquiring the license?
And was I better to go with the "Product Key" Option?
Thank you for the detail. To log in to your laptop's Vault Server through the Vault Client 2012 software, a license will need to be available. From the description, you will need to modify your LICPATH.LIC file to reflect your FlexNet license server's address. You can log into the Vault Server console without consuming a client license.
And if I get a license file from my reseller, how do I install the license file to the laptop? (In other words, can I have the laptop acting as my license server?)
You would need to install the FlexNET license server and configure the service to point to the new license file. Information on setting up FlexNET should be on the wiki - if not I can write up some steps here.
-OR-
You can point the LICPATH.LIC file on your laptop to your existing 2012 license server and pull a license if available.
Hi Andy Please explain how to set this up. I now have the license file.
Tom
read here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14379546&linkID=9240617
DarrenP
The License manager is installed per:
Once setup, yuo will need to create a new service and enter the path's to the correct locations. Besure to select teh Use Serivces and Start Server at Power Up (if you want it to turn on automatically). Once entered, save teh service.
Then switch to the Start / Stop / Reread tab and start the service. You will also want to re-read the licnse file, and then go to the Server Status dialog and perfrom an enquery to ensure the licnse is available.
