Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2010 can not check in large files
4 REPLIES 4
rogersodo
411 Views, 4 Replies
Get an error message when i try to check in files over 30MB. Error message: Aproblem occured while attempting to add the file ......The server returned the following information: Exeption has been thrown of target of an invocation.
Tried to do this, but it doesn't work: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=4445223&linkID=9261340. Does anyone have a solution to this problem? Se attached file.
4 REPLIES 4
Senthil_Kumar
in reply to: rogersodo
Is it possible to send ONLY the IPT file mentioned in the error message to me? You can send it at
senthilDOTkumarATautodeskDOTcom
I suspect some Custom Property in the IPT is preventing the check-in.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
rogersodo
Thanks for your reply! I tested to check in a another large file and get the same error message.
I can send it to you by "sprend.com", filename "crap.ipt". Thanx! / Roger Södö
Senthil_Kumar
OK. Please send me the files using Pack and Go. If the file size is large then let me know i can send you the Secured FTP Link. Send me an email so that i can use that for the Link.
Senthil Kumar
Autodesk, Inc.
Senthil_Kumar
Here is an update to this issue in case if anyone faces the same issue.
we were able to make the check-in work by increasing the request size in IIS (see the section on configuring IIS manager in the link below):
http://www.shubho.net/2011/01/http-error-40413-not-found-request.html
Senthil Kumar
Autodesk, Inc.
