Hi Chuck_B,
- Kindly define in more details what seems to be the experience you're
having with R2009.
- Do you have SQL2005 SP2 installed?
b) Open SQL Server Management Studio, r-click on the
[MACHINENAME]\AutodeskVault and select Properties.
- *Peform following OFF Hours i.e. no active user<>vault
communications.*
Titled "Creating a Microsoft SQL Maintenance Plan" on page 40 of the
Advanced Configuration Guide (ACG) for R2008, you will find steps I'd
like you to run at least once before proceeding further with this
investigation. After you've setup the plan in SQL Server Management
Studio, you may decide to r-click on the maintenance plan and Execute
it manually, too. It is located in the left-side Object browser >
Management > Maintenance Plans > [YourMaintenancePlan]
The ACG2008 can be found at
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9594013
&linkID=9242499. We're currently working on ACG2009, but AFAIK,
abovementioned area isn't being changed.
HTH,
-mg
