Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault 2009 Copy Design crash
3 REPLIES 3
395 Views, 3 Replies
I am having a problem with Vault 2009.  I am trying to copy design on a cabinet with multiple parts and it gets to 2% and then just quits?  Vault stay open but copy design window is gone and pop up window that shows % done is gone.  There is nothing in the folder I was copying to.  I tried this multiple times and the same thing happens.
Any suggestions?
D Herberger
3 REPLIES 3
Andy.Spivey
Is this with a single dataset or any files you try to copy design from?
Are there any errors or messages in the vlog from the same time as the copy design execution?
Andy Spivey
SQA Engineer
in reply to: Andy.Spivey
I have tried copy design on other models and they work.  Not sure where to fine the vlog that you mentioned.
D
Andy.Spivey
Referencing the Wiki:
Folder location and file names:
Microsoft Windows™ XP / Server 2003  - C:\Documents and Settings\All Users\Application Data\Autodesk\VaultServer\FileStore
Microsoft Vista™ / Windows 7 / Server 2008 / Server 2008 R2 - C:\ProgramData\Autodesk\VaultServer\Filestore
Vlog-YYYYMMDD.txt
Are you able to create a dummy vault and add the failing dataset to it?  With the dataset in a few vault, are you able to do a copy design?
Are there any 2009 Hotfixes installed in your environment?
Andy Spivey
SQA Engineer
