Mikel, that does help a lot to understand the reasoning behind some of the
changes; thanks.
One thing it doesn't address is the fact that a lot of new functionality was
added to the lower-tier Vault offerings, at the cost of a major functional
regression in Vault Manufacturing. We really want back our nice, simple
visual indicators as to whether something is (or even can be) checked out.
The goodies that cost us that indicator are useless in an ECO-driven
environment, which is the entire point of Vault Manufacturing. We're really
feeling like we got the snub this time around--which is frustrating given
all the things in VM that really do need some attention. Is that hotfix
fixed yet?
On another subject altogether, next time you see the suit that brilliantly
decided to change the name, tell him or her that "Productstream" is easy to
remember, easy to say, and sounds cool. "Vault Manufacturing" is a kludge
of a tongue-twister that makes one look stupid when one says it, and is
really easy to confuse with too many other things called "Manufacturing"
when you work in an actual manufacturing environment.
Cheers,
Walt
"Mikel Martin" wrote in message
news:6276128@discussion.autodesk.com...
We don't just use our product in a lab (though we do that too), we
actually use it to manage our documents for the Data management team.
But I would agree it is not the same thing as using it with Inventor,
for example. Which is why we try to stay in contact with our customers
as much as possible.
As for the Check Out workflows that were changed. I think that we have
done a poor job of communicating this change and how we expect it to be
used within the CAD application.
The Get / Check Out dialog is not as much a replacement for Check Out as
it is a replacement for the Get command. This dialog has several
functions and workflows. For example you can Get Latest, or Get a
previous Document Revision. The ability to Check Out is a secondary
workflow in this command.
We also changed the Check Out command to be more streamlined and less
bulky. You will see that the Checkout command no longer has any dialog
at all. You may also have noticed that you not have the ability to
multi-select in the Vault browser. With these two changes you can
multi-select any files that you would like to check out and select the
Check Out command. All selected files are latest and you have write
access to will be checked out. Any files that cannot be checked out will
be skipped with no error.
Our intent was to streamline the check out process and also add
functionality to the Get command which allows check out, instead of
needing a second operation.
Hope this helps.
Mikel Martin
Autodesk Data Management
Product Design Lead
-----Original Message-----
Posted At: Wednesday, October 21, 2009 4:06 PM
Posted To: autodesk.vault
Conversation: VM 2010 Major issues.
Subject: Re: VM 2010 Major issues.
I can see that Autodesk uses some of this stuff but as stated it's a lab
rat. The conditions are set perfect in a perfect world making widgets
and programmed items that are NOT real world stuff. More of a simulated
work condition. And this is fine however when the rubber meets the road
the car hit's the ditch! And I know like all companies big and small,
when the Executives get involved it usually makes an engineers life
miserable. Which can also cause this condition.
Some of my complaints are that the new version of the vault (2010)
"Check in Check out" procedures has been made overly bulky and clumsy to
use. Before we had Icons which gave us vault status.... no matter who
had what checked out. Now this icon only reflects our local
workstations. Before we used to hover over the said Icon and it would
readily tell us who had it checked out... now it just graysout the file
in a sea full of black text
(Try and see that on a Monday morning) and we have to turn on the
"Checked out by" column to see who the offender is. The 'Check in /
Out' from Inventor We can check in a complete Assembly by checking in
the top level but checking out we have to hop and skip thru to pick
selected files. For what purpose did they remove the dialog box by
which we could check and uncheck Groups of items. Now we have to expand
the Assembly tree (which takes longer than it should BTW) in the
browser in Inventor and select one at a time or hold shift to select
all. Either way it's way more involved and time consuming to funtion!
C'mon guys, sometimes changing things just to chnage them in order to
make 2010 different somehow from 2009 isn't really helping anyone!
Frustration with this new interface fitting with our workflow I know, is
the just a taste of what Autodesk SHOULD be listening to. And I haven't
spoken to one person yet that has the "New Vault Manufacturing" that has
thought it was an improvment.
Luke
