Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
VC 2012 vault to VC 2013 as 2nd vault
2 REPLIES 2
267 Views, 2 Replies
Does anyone have a workflow for moving a Vault Collaboration 2012 vault database from one server to a vault collaboration 2013 server as a second vault ie there is already a vault running on the 2013 vault.
2 REPLIES 2
herrerh
This is not recommended nor supported.  A Vault should only be used with the original Knowledge Vault master that it was created with.  Moving the vault from one server to another with an already existing vault would require that you use the Knowledge Vault master on the newer vault which would be different.
Hywell Herrero
Data Management Support Specialist
Product Support
in reply to: herrerh
I'm aware that the user ID numbers would be diferent, but is that the only issue, because I would really like to turn the old server off before it dies anyway!
