Does anyone know what this does?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Solved by Senthil_Kumar. Go to Solution.
Scott Moyse
Ok this works in Inventor, so it looks like it's broke in the Vault Client. I'll Escalate this to Product Support.
Scott Moyse
Scott,
It should work. After changing the setting, close the Vault Client and Restart to see the effect. By default Large status icon is enabled.
You can see the difference in the attached images.
With Large status icon Disabled
With Large status icon Enabled
Scott Moyse
Scott,
I will ask the help team to get that updated. Thanks for pointing that out.
Senthil,
If I'm honest, I'm not convinced restarting is 'As Designed' for two reasons:
Anyway, updating the Help file will certainly clarify the intent. Thanks for passing that on.
Scott Moyse
