Vault General
Distinguished Contributor
warrenandy
Message 1 of 3 (101 Views)
Uploading 200,000+ Drawings any advise?
101 Views, 2 Replies
09-08-2012 03:41 PM
This is probably the second biggest load their will be an even large one later this year. Any advise?
This 200,000+ is AutoCAD with a sprinkle of ACADE. Another 20-30k of Inventor files are already in. Then the larger will be a mix of AutoCAD and PDF files some of them probably date back to the 80's...
Andrew Warren
CAD & Data Management Specialist
Bridgestone Americas Tire Operations
andrew.warren@bellsouth.net
New Member
Message 2 of 3 (74 Views)
Re: Uploading 200,000+ Drawings any advise?
09-10-2012 01:59 AM in reply to: warrenandy
You may try with Autoloader which will be installed by Vault client.
-Frank
Valued Mentor
jclaidler
Message 3 of 3 (67 Views)
09-10-2012 04:53 AM in reply to: warrenandy
Load Inventor files first with 'Task Scheduler' in the following order:
  • parts
  • assemblies
  • presentation
  • drawing
Then using AutoCAD, use the 'check in folder' option.
This is the easiest process.  Not a big fan of Autoloader, except for the reporting part.
_______________________________________________________________
ITO - Application Management
Factory Design Suite Ultimate 2012
AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
