Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Uploading 200,000+ Drawings any advise?
2 REPLIES 2
warrenandy
207 Views, 2 Replies
This is probably the second biggest load their will be an even large one later this year. Any advise?
This 200,000+ is AutoCAD with a sprinkle of ACADE. Another 20-30k of Inventor files are already in. Then the larger will be a mix of AutoCAD and PDF files some of them probably date back to the 80's...
Andrew Warren
Manager, Engineering Services Support
Bridgestone Americas Tire Operations
warrenandy@bfusa.com
andywarrenbc@outlook.com
2 REPLIES 2
in reply to: warrenandy
You may try with Autoloader which will be installed by Vault client.
-Frank
john.laidler
Load Inventor files first with 'Task Scheduler' in the following order:
  • parts
  • assemblies
  • presentation
  • drawing
Then using AutoCAD, use the 'check in folder' option.
This is the easiest process.  Not a big fan of Autoloader, except for the reporting part.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
