This is probably the second biggest load their will be an even large one later this year. Any advise?
This 200,000+ is AutoCAD with a sprinkle of ACADE. Another 20-30k of Inventor files are already in. Then the larger will be a mix of AutoCAD and PDF files some of them probably date back to the 80's...
You may try with Autoloader which will be installed by Vault client.
-Frank
Load Inventor files first with 'Task Scheduler' in the following order:
Then using AutoCAD, use the 'check in folder' option.
This is the easiest process. Not a big fan of Autoloader, except for the reporting part.
