Vault General
Valued Contributor
Message 1 of 17 (409 Views)
Accepted Solution
Unable to get lic. 2013 wrkgrp new install
409 Views, 16 Replies
11-13-2012 01:00 PM
On a new install of 2013 WG, I can not get the lic to work. the server seems to be fine and the lic manager is reporting it is running and working.
tatus -------- Flexible License Manager status on Tue 11/13/2012 12:51
[Detecting lmgrd processes...] License server status: 27000@jcf64-eng     License file(s) on jcf64-eng: C:\VLTWG2013enlicense.lic:
 jcf64-eng: license server UP (MASTER) v11.10
Vendor daemon status (on jcf64-eng):
  adskflex: UP v11.10 Feature usage info:
Users of 85988VLTWG_2013_0F:  (Total of 8 licenses issued;  Total of 0 licenses in use)
The client is set correctly,
LMTOOL LOG:
5:15:15 (lmgrd) pid 3600
15:15:15 (lmgrd) Detecting other license server manager (lmgrd) processes...
15:15:15 (lmgrd) Done rereading
15:15:15 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96515 x64_n6) started on jcf64-eng (IBM PC) (11/12/2012)
15:15:15 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
15:15:15 (lmgrd) US Patents 5,390,297 and 5,671,412.
15:15:15 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
15:15:15 (lmgrd) License file(s): C:\VLTWG2013enlicense.lic
15:15:15 (lmgrd) lmgrd tcp-port 27000
15:15:15 (lmgrd) Starting vendor daemons ...
15:15:15 (lmgrd) Starting vendor daemon at port 2080
15:15:15 (lmgrd) Using vendor daemon port 2080 specified in license file
15:15:15 (lmgrd) Started adskflex (pid 2888)
15:15:15 (adskflex) Unable to initialize access to trusted storage: 1
15:15:15 (adskflex) FLEXnet Licensing version v11.10.0.3 build 96515 x64_n6
15:15:15 (adskflex) Server started on jcf64-eng for: 85988VLTWG_2013_0F
15:15:15 (adskflex) EXTERNAL FILTERS are OFF
15:15:15 (lmgrd) adskflex using TCP-port 2080
21:15:17 (lmgrd) TIMESTAMP 11/12/2012
21:20:17 (adskflex) TIMESTAMP 11/12/2012
 3:15:18 (lmgrd) TIMESTAMP 11/13/2012
 3:25:19 (adskflex) TIMESTAMP 11/13/2012
 9:15:19 (lmgrd) TIMESTAMP 11/13/2012
 9:30:21 (adskflex) TIMESTAMP 11/13/2012
12:51:52 (adskflex) TCP_NODELAY NOT enabled
I am currently running Inventor 2010 on another different computer and different name, The 2013 WG login is pointed at the new server.It also sees the Vault when search for it, so it does see the server just fine.
any ideas?
TK
*Expert Elite*
DarrenP
Message 2 of 17 (406 Views)
Re: Unable to get lic. 2013 wrkgrp new install
11-13-2012 01:15 PM in reply to: steamer90638
whats the error you get when you log in to the vault workgroup client?
Valued Contributor
Message 3 of 17 (403 Views)
11-13-2012 01:22 PM in reply to: DarrenP
see attached screen shot, ***failure to aquire license***
*Expert Elite*
DarrenP
Message 4 of 17 (400 Views)
11-13-2012 01:23 PM in reply to: steamer90638
are the license manager and the ADMS Console on the same machine?
Valued Contributor
Message 5 of 17 (398 Views)
11-13-2012 01:25 PM in reply to: DarrenP
Yes it is.  here is part of the lic script.
SERVER jcf64-eng 001018F345F8
USE_SERVER
VENDOR adskflex port=2080
INCREMENT 85988VLTWG_2013_0F adskflex 1.000 permanent 8
*Expert Elite*
DarrenP
Message 6 of 17 (396 Views)
11-13-2012 01:27 PM in reply to: steamer90638
Valued Contributor
Message 7 of 17 (395 Views)
11-13-2012 01:31 PM in reply to: steamer90638
another attachment
Valued Contributor
Message 8 of 17 (393 Views)
11-13-2012 01:33 PM in reply to: steamer90638
I am not running in IPv6, only IPv4 and only single network card.
*Expert Elite*
DarrenP
Message 9 of 17 (384 Views)
11-13-2012 02:44 PM in reply to: steamer90638
what about firewall did you unblock these ports:
The FLEXlm® based version uses the following ports:
  • TCP ports 2080 (for the adskflex vendor daemon)
  • TCP ports 27000 to 27009 (for the lmgrd master daemon)
Valued Contributor
Message 10 of 17 (382 Views)
11-13-2012 02:56 PM in reply to: DarrenP
No firewalls running no AV running. Pretty naked  if I do say so. WG does see the Vault, just cant see LM. On the client side is there something beside the normal WG being istalled that should be running, how does WG see the LM aanyways, or how odes it know to request from it.
TK
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
