I'm trying to track down a persistent problem with IDW's processed with the JP. I suffer the odd crash of the silent Inventor but looking at jobprocessor.log I can't see anything. All I'm left with is manaully opening each IDW and switching to the Vault tab to see if the IDW is dirty or not. I can see in jobprocessor.log that job 71622 was started and completed. But how do I see what file was the source of the job? IS there another log file somehwere where I can tie up the IDW that is dirty with a job number or something to track down the events?
Hi Brenden - You could try enabling extended Logging for Job Processor, please follow the below steps -
1. Navigate to Path "C:\Program Files\Autodesk\"Vault Version"\Explorer\"
2. Backup the Job Processor config file "JobProcessor.exe.config" just in case.
3. Change the vaule of the key <add key="LogLevel" value="0" /> from 0 to 1 <add key="LogLevel" value="1" />
You should now see new logs with this naming convention "Unique ID + JobProcessor.log" under the path "C:\Program Files\Autodesk\"Vault Version"\Explorer\" with more details.
Hi Bharath.
I can't find the section that code is in. Where should I add the line?
