Right, so I applied the non public workaround to fix this:
Visual Data Management Not Working in 2015
Then I got this error:
and fixed it....
Now I'm getting this error:
How can the Visual Data Mapping be SO broken in 2015? Amazing. AND we are nearly 3 months since RTM was released.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
I'm using Windows 8.1... it appears this error is happening with Inventor 2014 as well.
Scott Moyse
Right, so even though my Windows user has full admin rights, I'm having to run Inventor using the 'Run As Administrator' option from the context menu on the taskbar... or the start menu.
I'm loath to mark this as a solution.
Scott Moyse
Hi Scott,
just want to ask if you could try disabling UAC and see if the problem still persists:
Thank you
I never have UAC enabled.
Scott Moyse
Hi Scott
Thought id drop this previous post you were involved in.
Does this help?
Regards
Paul
Thanks Paul... thats the fix I summarized in the blog post I linked to in the OP. I doesn't help here and Autodesk Support are being remarkably slow to react to this issue.
Scott Moyse
@PACDrafting wrote:
Sorry just clicked on your link to this previous post.
Another error!
Hopefully Senthil fixes this as well.
No need to be sorry. Nice to know you've got my back!
Scott Moyse
Hi Scott,
1. 'The template is read only. The template will not be updated. Contact the template author' - message is seen when you do not have the write access to the template. Please check if you have write access to template you are using.
2. I checked with on Windows 8.1 with VP2015 RTM client + Hotfix for Data Mapping Update (required Micosoft Report Veiwer 2010) - I can see the data mapping working.
Regards.
Yogeshwar Gandhe
(Autodesk - Vault team)
I have a brand new, fresh operating system, with everything fully patched, local user (Microsoft Account) has full admin rights and this is still happening. It will ONLY work if I start Inventor using Run As Administrator.
Maybe you were using a Domain account on Windows 8 or a local account rather than a Microsoft one? maybe that makes a difference? It works normally in my Windows 7 VM.
Scott Moyse
Buenas tardes, Alguien ya conoce cual es la solucion? tengo el mismo problema y quisiera conocer que pasos seguir. Agradecemos cualquier ayuda.
Gracias
Had this happen on a set of machines running 2018 last week. Not only this one, but it was then followed up with the "template is read-only" issue too.
Time for a fix?
Not sure if you've been able to resolve this already. I have found that if you copy the template .rdlc files out of their default folder into a more "user friendly" folder (tested with Desktop), that you do not need to "Run as Administrator" and the mapping works as expected.
