I work with Inv 2012 and Vault basic 2012. I wanted to check in fileswith the Task Scheduler but when I go
to Create task the Check in task is not there. Every task related to vault is missing. Is this a known issue?
The vault is working fine and I can check in/ out files from INV without problems.
Dan
Hi Dan,
Vault related commands should be available in Task Scheduler. Could you please try a repair install on Inventor and Vault?
