Since it is stating "Failed at child", try to run the update on .ipt's only,
then check in the child files. Repeat for the .iam's, then check in the
assemblies. Are these derived components by the way? Are you using any of
the AIP modules in these files?
Brian Schanen
Customer Success Engineer, Data Management
"karthur" wrote in message news:5835843@discussion.autodesk.com...
> I am trying to use the Task Scheduler to update and check-in all the files
> in a job that I have completed. I created a task to update the files and
> another task to check them back into the Vault.
> When I ran the task to check-in, there were several files that did not
> check-in. When I looked at the log, I see "Failed at Child" listed by the
> files. In Inventor, I can open and check these files in with no problem.
> What is the problem with the task scheduler checking them in?
> Inventor 200
> 8 - SP2
> Vault 2008 - SP1
