Hi All,
We have been using Vault Manufacturing 2010 along with Inventor 2010. In one of our systems, we found that in the Inventor Ribbon, under the Vaulyt Tab, some of the major options like LOG IN, LOG OUT, OPEN & Place are missing.. We are unable to find them.
Can anyone help us in this regard..?
See the snapshot attached..!!
Thanks & regards,
Himanshu Malhotra
Solved by luttena. Go to Solution.
Hello. Thanks for posting your issue. It seems your 'EDM Addin' has been disabled. In Inventor, open the 'Add-in Manager' dialog and right-click in the white space. Select 'Show hidden members' option. Now you will see the 'EDM Addin' in the list. Check both boxes for loading.
Let us know if this doesn't solve the issue for you.
Adam
