I would like the ability to toggle whether Sheetset is associated with my Vaulted drawings or not.
If I use sheetset without Vault, the sheetset is very fast. If I use a sheetset that has been checked into Vault, it slows down tremendously. The slowness is also associated with the drawings as well. Has anyone had this happen?
I find there are several issues with sheet sets and Vault. For example, in the sheet set manager you can see the Vault status of files. However, once the Sheet Set has been checked in, you cannot use the manager to check it OR individual sheets OUT again.
I've also noticed you cannot use Copy Design on a sheet set. You have to copy each sheet individually, create a new sheet set, and then add the copied sheets. I've put this one into the Vault idea station:
Feel free to add your own ideas... and if you like this one give a kudo.
Good luck!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
