Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
STP files in company's library
2 REPLIES 2
BeKirra
257 Views, 2 Replies
We often receive equipment drawings from suppliers. for example, fan models.
In most cases these models are stp files.
IAM files will be created and automatically be placed to "Imported Components" folder when stp files were inserted to assembly.
By using vault, how to manage these files in company's standard library directory?
Thanks in advance.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
2 REPLIES 2
swalton
in reply to: BeKirra
Do you want to store the source stp files in Vault?
If so, I think you have to use the vault client and import them without using Inventor.
You may be able to create a "3rd party file" link in the Inventor file, but I have not researched it.
Steve Walton
Inventor 2023
Vault Professional 2023
BeKirra
in reply to: swalton
Thanks for your help.
I am new in using vault.
Quote 1:
What is the pros & cons to store the stp files in vault?
Quote 2:
How to use vault client import the stp files?
Quote 3:
I have never heard about this. Need more info.
X² + Y² = C²
