The best thing to do, if you don't want to use the MSDE instance that the
server will install, is to install a new instance on your server, called
"AUTODESKVAULT", setting the "sa" password to "AutodeskVault". Then, the
Vault 4 server installer will use that instance.
jeff
wrote in message news:5060675@discussion.autodesk.com...
Do you have any tips & tricks for installations of Autodesk Data Management
software; Vault 4, Content Centre files... onto an existing SQL Sever?
Robert
