Hi guys.
I'm soon to be building and replicating a Vault from Sydney to the UK (full proper SQL workgroup replication), unfortunately the 300GB+ of data is too large to replicate with the servers in-situ. My original plan was to courier the UK servers to Sydney and replicate locally before shipping the servers back to the UK. However, I need a plan B.
I understand it's possible to pre-copy a filestore from the publisher to a subscriber prior to enabling workgroup replication, so then it uses and validates that filestore without copying the bulk of the data. My question is, is it possible to do this also with the user and system databases i.e. the vault DB, the KVM etc? Basically, can I copy everything the Vault needs onto an external HDD, fly back to the UK with that HDD, move the data onto the UK servers into the right place and then enable replication without it needing to copy large portions of data to build the instance on the subscribers?
Any help is greatly appreciated.
Ta. Neil.
Just as a follow up, if this is possible, it would probably be my plan A as shipping physical servers is a logistical nightmare.
If only you had Vault Professional.
This would have enabled you to setup the AVFS (Autodesk Vault File Server).
See details if required: http://knowledge.autodesk.com/support/vault-products/downloads/caas/downloads/content/autodesk-vault...
I'm confused, someone called KopexWaratah responded saying:
"If only you had Vault Professional.
This would have enabled you to setup the AVFS (Autodesk Vault File Server)."
But I can't see that response in the forum, very weird. Watch it appear after I write this!
Anyway, thanks for the response. Obviously this client does have Vault Pro, else full replication wouldn't be an option. Unfortunately AVFS isn't going to be suitable to cater for these geographics, meta data transfer on the latency experienced between Australia and UK won't be acceptable therefore AVFS won't be suitable. It has to be full replication.
I've since spoken with Autodesk who have offered an option regarding how to move a subscriber, so I have a few things I can test for now. I'll update this thread if it works!
Yep that's exactly what I have here, two sites that are on different sides of the world with a very poor line between them.
Your plan B which you are hoping is your plan A is something we will be trying between Newcastle and Poland.
I'll bookmark this section as well.....
Yep know Symetri. But wasnt aware of them being in Newcastle Australia?? Guessing your thinking Newcastle UK!!
I'm on linkedin with Chris Atherton. Guess you know of him...
Yep plan is to copy all data on to an external drive and fly over, setup in Poland and off we go.........
