Vault General
Active Contributor
bmyers
Message 1 of 5 (127 Views)
Removing Vault
127 Views, 4 Replies
03-22-2013 06:55 AM
I have a client that hasn't used Autodesk Vault in approx. 2 years. They were using Vault 2011.  They would like to now remove all the files from the Vault server and (obviously) keep the same file names, etc. so they can simply back the data up on their high capacity server.
The question: What's the process to remove all the files from a Vault while keeping the proper directory/naming scheme?
Brian Myers
Sr Applications Engineer - Autodesk Revit Architecture Certified Instructor (ACI)
Seiler Instrument, St Louis MO
Message 2 of 5 (114 Views)
Re: Removing Vault
03-22-2013 08:46 AM in reply to: bmyers
This wouldn't involve setting up a vault client on your new server and just performing a massive get folder command? Does your client intend to capture all of the old version files as well?
Active Contributor
bmyers
Message 3 of 5 (109 Views)
Re: Removing Vault
03-22-2013 09:17 AM in reply to: kenjacques8585
They want to retire the Vault server and remove/salvage as much of the Vault data as possible.  They discussed internally setting up a newer version of Vault, but decided Civil 3D (the software they used it the most with) could now handle everything with data shortcuts, etc good enough to not require Vault anymore.
But to answer your question directly, they would like to capture all the "current" files and move them onto their normal, office network... then retire the Vault.   My Vault knowledge is fairly light, but obviously they could open each file individually and do a "save" to a network location.  Of course, this is also insanity because of the length of time it would take.  They are not worried about Revisions, Versions, etc (so no, they don't care about those old files) ... just their "current" Vault files.
As I think about it, I'm beginning to realize the difficulty of this if an Automated tool isn't available for the task... so I hope my limited knowledge is missing something obvious.
Thanks in advance.
Brian Myers
Board Manager
Message 4 of 5 (104 Views)
Re: Removing Vault
03-22-2013 09:49 AM in reply to: bmyers
Open the Vault client.
Right-click on the root folder ($) and select Get.
This will get all of the latest versions of the files and keep the folder structure.
Irvin Hayes Jr
Product Manager
Active Contributor
bmyers
Message 5 of 5 (101 Views)
Re: Removing Vault
03-22-2013 09:55 AM in reply to: ihayesjr
That's the easiest question you'll need to answer today. :smileywink:
Thanks.
Brian Myers
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
