Hi Matthijs,
Thomas is correct that the numbers reflect the progress 'ticks'. For each
vault, there are a few discrete operations per backup - e.g. backup the
database, backup the filestore. So the total for the data in the screenshot
might be 1 (knowledge master) + 7 (library databases) + 17 (vault databases)
+ 17 (vault filestores) = 42 (which is number of steps in the first backup
logged)
ADMS console takes the approach of basically logging out information that
the user sees - in this case it is probably not that helpful. However, the
number will always be fixed based on the total number of vaults and
libraries on the system. Deleted vaults should never affect this count.nor
should they affect the backup time.
Paul
wrote in message news:5895115@discussion.autodesk.com...
Hi Thomas,
Thanks for your reply.
You are right, if I check the backup database subfolder, it only contains
the vaults that are shown in the ADMS Console. And for now there isn't a
real problem.
But considering our workflow, it is most likely that we have to create, and
afterwards delete, a lot of vaults. If we continue like this and we aren't
able to tackle this, I fear that backing up could take a lot of time and
that the log file isn't readable any more.
Matthijs
