I see that the Reference Repair Utility (new in Vault SP1) is automatic in paid for Vaults (Workgroup thru Pro) but only manual in the Basic edition, what is the reason for this?
Regards
MattH
If I remember well when I discover this bug, I saw there are some additional SQL tables in Vault W-C-P that stored which file is linked with other. Then, the repair utility probably use those tables.
For Vault Basic, the only table that store links is the table who was too much purged...
Reference Repair Utility is for Vault Basic as well as Workgroup and higher editions of Vault and this is a manual process regardless of the edition of Vault. Whereas automatic repair is done as part of installation of the Service pack and this only applies to data created in Workgroup and higher editions of Vault, because of the information that is available for that data. However, auto repair may not address all cases, that is why it is highly recommended to run the Reference Repair Utility and go through the manual repair process for Workgroup and higher editions of Vault as well.
Hope that helps.
Anil Chintamaneni (Autodesk)
