Dave,
Yes, SP4 is fine, but you'll need Vault 4 with Sp2 installed or you won't be
able to login and work with the Vault.
Some other tidbits on DB growth and Vault purging and reindexing..
Doing a purge will request more space within SQL..The default value for DB
growth in SQL is 10%. Therefore, when you do a purge SQL tries to reserve
10% for growth (not that it will need it necessarily) so if you're at 1.8 GB
you will just get by, however, if you are at 1.9 Gb it will try to grow to
2.09 Gb.. thus, if you're on MSDE you'll hit the wall.
Also, if you purge the DB the file size won't shrink either. It will clear
out space inside the SQL tables that SQL/Vault will use up completely before
it begins or needs to grow again. So, purging can buy you some time, but if
you wait too long even purging won't/can't help because it cannot reserve
the 10% needed to perform the purge.. and it will fail.
Bob
"Dave Hoder" wrote in
message news:5072416@discussion.autodesk.com...
No, SQL2000 sp3a
Have you tested sp4?
