Vault General
Distinguished Contributor
BSchubring
Message 1 of 11 (300 Views)
Accepted Solution
Purging options, keep original plus last 6 versions (Vault Pro 2012)
300 Views, 10 Replies
11-09-2012 10:06 AM
Hi, I'm reading about the options available to purge extre versions of a drawing from Vault through the ADMS.  What we want to do seems 90% covered except for one small snag.
We'd like to keep the last 6 versions of a file (supported), AND the initial version (I don't see that option). My CAD group does not want to lose the ability to go back to the original version of a file as received from the customer.  There are no reliable comments or dates to filter this on, so what are my options (if any)?
Thanks!
(This is the page I'm referencing)
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0097-Administ97/0098-Autodesk98/0099-Manage_V99/010...
Valued Mentor
jclaidler
Message 2 of 11 (296 Views)
Re: Purging options, keep original plus last 6 versions (Vault Pro 2012)
11-09-2012 10:10 AM in reply to: BSchubring
Add this to your backup script.  Modify for the version of Vault, vault name, backup login and password
"C:\Program Files\Autodesk\ADMS Manufacturing 2010\ADMS Console\Connectivity.ADMSConsole.exe" -Opurge -N<<vaultname>> -KEEPVERS6 -EXCLCMT "Do not purge" -VU<<login>> -VP<<password>>
_______________________________________________________________
ITO - Application Management
AutoCAD 2014 | Inventor Professional 2014 | Vault Professional 2014
BSchubring
Message 3 of 11 (293 Views)
11-09-2012 10:12 AM in reply to: jclaidler
Thanks, can you explain how this script keeps the original, or does Vault always do that atomatically? I don't recognize a  parameter in there that does that portion.
Valued Mentor
jclaidler
Message 4 of 11 (286 Views)
11-09-2012 10:21 AM in reply to: BSchubring
If you don't have the 'basic' Vault, you can 'release' the original.  What version of Vault are you using?
BSchubring
Message 5 of 11 (284 Views)
11-09-2012 10:23 AM in reply to: jclaidler
Vault Professional 2012. We're prepping for an upgrade to 2013 next week, and I'm trying to trim down the size of the DB before the final backup and transition to 2013.
Valued Mentor
jclaidler
Message 6 of 11 (281 Views)
11-09-2012 10:25 AM in reply to: BSchubring
Set the state of the originals to 'released', those won't be purged.
BSchubring
Message 7 of 11 (272 Views)
11-09-2012 10:37 AM in reply to: jclaidler
Ah, I see. I went into our Workflow, checked the initial Receved state we made and checked the box to make it a Released state. This should prevent it from being purged if I understand correctly. Many thanks for your assistance!
Valued Mentor
jclaidler
Message 8 of 11 (268 Views)
11-09-2012 10:49 AM in reply to: BSchubring
No problem.  Good luck in your upgrade to 2013.
xdumont
Message 9 of 11 (243 Views)
11-11-2012 11:33 PM in reply to: jclaidler
DON'T Purge !!!
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18480860&linkID=9261341
There is an issue with the purge. You have to install the hotfix above, this will disable the purge in order to avoid the loss of file dependencies.
BSchubring
Message 10 of 11 (184 Views)
11-21-2012 10:17 AM in reply to: xdumont
Yikes, didn't see this until after it was completed... Gonna hope for the best. Thanks for the warning, I'll get this installed ASAP.
What is the exact risk here?  What dependencies are at risk?
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
