Hi
I have edited a lot of files in Vault and added formulas for properties. I use Edit Properties and paste the formulas in for the properties. When updated everything looks fine. When I find the files in Vault Explorer I can see that the properties have updated and is showing me the result of the formula. Excelent!
BUT, now I want to assign Item for the same files and export the data to ERP. And here the properties are showing the actual formula - and not the result of the formula. Please see attached pic for a small example.
I do not understand why there should be a difference in this in Explorer vs Itemmaster (maybe a bug??). But how do I fix this? The only way I know of is to check out every single file and manually update them. And in fact sometimes I need to force the update of the properties of the parts by moving the "End Part" up and down on the ipt. Unfortunately I do not know which files is edited. So I have to do this with every file in the entire Vault (hopefully with task scheduler or something). If there is not an easier solution...
So please if anyone have a solution for this or any good advice, please post it
Best regards
TG
We are using Inventor 2013 and Vault professional 2013.
Best regards
TG
I just tested on our 2013 level (Vault Pro/Inventor) and my items show the formula results. Have you applied service pack 1 for your server/clients?
How is your properties mapped in vault for Title (ITEM,CO) or the other one in your image? Is it mapped bi-directional (vault<-->inventor) or one direction (vault<---inventor). Just trying to narrow it down to settings (or a service pack issue).
Hello, again
The fact that it works on your system gives me hope that there may be a simple solution.
I attached a pic of 3 of my mappings.
As I mentioned in my last post all systems are updated.
Best regards
TG
