Translation of question
_________________________________________
if we can set a fixed working folder in PS, in Check out dialog, the file path will be locked, but in Get Previous Version/Get Latest Version, you will find the file path is the fixed working folder we set before, but why is it can be changed? any way to fix it in Get Previous Version/Get Latest Version
__________________________________________
About why the file path can be changed in Get Previous Version/Get Latest Version. there are two points
1. For Get Previous Version, we allow user to change file path to avoid replacing the file version in working folder with a previous version, which may cause the customer changes lost. for users, they wanna get a previous version ,perhaps, just for review or compare. so we give use the choice to get the file to another folder and reduce the risk of replacement in working folder
2. Another situation is it may have been a file out of date in working folder, but it really is the one user Anna edit. if we get latest version with fixed working folder path, this file will be replaced by latest version, user may lost chance to edit wanted file version. so in get latest version, we also allow user to change file path.
and now, it seems we cannot to set fixed path Get Previous Version/Get Latest Version, but we will take care this issue.
Thanks for your question and hope this information will help you
Elwen
关于为什么可以在 "获取老版本”和“获取最新版本”更改路径,主要有两点
1. 对于获取老版本,如果我们把路径限制为不可更改的固定工作文件夹,那么就会造成用老版本的文件替换掉工作文件夹里面比较新的文件版本, 这样用户就会丢掉他们所做的一些修改造成损失.有时,用户去拿一个过去的版本,只是为了浏览或者比较,所以我们允许用户这时把文件放到其他文件夹保存以减少风险
2.另外一种情况就是, 有可能工作文件夹里面的文件不是最新的,但是这个就是用户想要编辑的文件.同时用户又想根据最新的版本做参考,如果我们在“获取最新版本”设置固定工作文件夹, 那个就会把用户想编辑的文件替换掉,所以在“获取最新版本”时, 我们也允许用户这时把文件放到其他文件夹保存
所以目前我们还没有办法去固定“获取老版本”和“获取最新版本”时出现的对话框路径.不过,我们会继续关注这块!
谢谢你的提问,希望这些信息有用
Elwen
