Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Problems with copy design or rename when using numbering schemes
5 REPLIES 5
documentation
750 Views, 5 Replies
We are trying to implement numbering schemes in vault workgroup 2011 using our predefined categories and using an auto-generated number sequence. while testing we came across two problems:
1 - When using copy design the numbering scheme is not accesible, temporary file names must be given to later use the rename function.
2 - When using the rename function on an IDW and its associated IPT or IAM will result in incrementing both file separatly and giving them different file names.
Example:
ABC001.idw - rename to new category - XYZ001.idw
ABC001.ipt   - rename to new category - XYZ002.ipt
Thank you,
Jason
5 REPLIES 5
A hotfix has been released for the renaming issue :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=16428729&siteID=123112&linkID=9261341
Now that the rename function has been addressed are there any plans to incorporate the numbering scheme with copy design?
Thank you.
RobRidings2
in reply to: documentation
Is there any news on incorporating the numbering schemes in the Copy Design tool?
We are currecnlty using the same filename for the ipt/iam and idw.
Without this we are having to first copy the design, then apply the numbering scheme to the ipt/iam's, and then finally updating all the idw names to match the ipt/iam's manually.
Inventor Pro 2021 Pro
Vault Pro 2021 Pro
Revit 2021
Navisworks Manage 2021
Windows 10 v1909, 64-bit
Intel i7-6700K @ 4.0GHz
64GB
Nvidia Quadro M4000
achintam
in reply to: RobRidings2
We are aware of this limitation and we are looking at addressing it in a future release.
Anil Chintamaneni (Autodesk)
koeltzsch
in reply to: achintam
I skip posting a new thread about this topic.
I'll add here the same request to enforce the need of such a functionality. Both commands (numbering scheme and copy design) are very helpful functionalities inside vault but must be combined as soon as possible. It is absolutely inconvenient being forced to use the rename-command only to get auto-numbered the copied files. It's very time-consuming and leads to more unnecessary file versions.
We're facing more and more situations where this scenario occurs - that's why it would be greatly appreciated to have this issue fixed within the next vault release 2014.
Autodesk - please prioritize this!
Thanks and Regards,
DK
documentation
in reply to: koeltzsch
Just installed 2013 and disappointed the numbering scheme functionality within a copy design has not yet made it into any releases since 2011. Upon recommendations from our software reseller we are on a two year install cycle..... So here’s looking at 2015.
Please add.
