Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Problem entering information into Data Card
1 REPLY 1
jeff.noel
223 Views, 1 Reply
So I have a property in Vault setup that has one item setup in the List Values field.  I also have Enforce List of Values set to False and Requires Value set to False.
Now I also have that property setup in a Data Card.  When I go to edit that Value in the Data card, it will only drop down with the list of Values, but I also want people to have the ability to enter in their own property too (hence why enforce list of values is set to false).
It seems to work find if I do an Edit Properties inside of Vault, but if I edit it in the Data Card it enforces the list of values.  Am I missing something or is this a bug in Inventor/Vault?
1 REPLY 1
Madhan_T
in reply to: jeff.noel
Hi Jeff,
Thank you for reporting this issue. I have forwarded this to the development team. I will keep you posted about the updates.
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
