I'm not aware of how to estimate the metadata size based on total files
size, but I would suggest start with SQL Server 2005 Express. The main
advantage of SQL Server 2005 Express is max. database size is 4GB as compare
to MSDE which is 2 GB. The upgrade from SQL Server 2005 Express to full SQL
is not difficult. More information can be found from Advanced Configuration
Guide for Autodesk Data Management Server 2008
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9594013&linkID=9240618
Even though Vault 5 install MSDE by default, it can be upgraded to SQL
Server 2005 Express. Search for a folder name "UpgradeSQL2005" inside the
installer CD, and run the setup after installed the Vault server. Vault 2008
and 2009 install SQL Server 2005 Express by default.
Chee-Kit
"Ramil" wrote in message news:5946659@discussion.autodesk.com...
> Thanks Chee-Kit,
> Yes, we have Inventor 2009 license.
> What about the database server? Is it OK to use MSDE?
> I am thinking to start using MSDE as oppose to Full SQL.
> We have only 3 users, possibly 4 in the near future. At the moment,the
> size of our files is about 25 GB. I do not expect it to increase double in
> the near future. As for the metadata size, Is there a way i can obtain the
> size at the moment with Inventor 11. Would that increase dramatically with
> Inventor 2008 or 2009?
