Greetings!
I am trying to install Vault Server 2013 on my Win Server (2003) and when I get to the pretest it either freezes or I receive the following error: "The website Default Web Site has extra ISAPI filters installed. This may affect the operation of the Vault."
I have navigated to the default web site in my IIS manager and removed said filters. However, I still get the error. I tried rebooting and running again, still the same error.
(Log file as as follows:)
Autodesk Diagnostic Tool Log File
Checks
Name Information Result
Verifying that a reboot is not pending.
Successful
Checking Operating System Caption=Microsoft(R) Windows(R) Server 2003 for Small Business Server
CSDVersion=Service Pack 2
OSLanguage=1033
OSProductSuite=305
OSType=18
ProductType=2
ServicePackMajorVersion=2
ServicePackMinorVersion=0
SuiteMask=305
Version=5.2.3790
Successful
Checking for a Proxy Server
Successful
Validating Performance Counters
Successful
Checking port 80 for availability
Does not apply.
Validating that IIS Anonymous User Account is set up correctly Anonymous user "IUSR_DELLSBSR2" found.
Successful
Validating that IIS Anonymous Authentication on IIS is set up correctly
Successful
Validating IIS .Net settings
Successful
Checking for additional IIS ISAPI filters fpexedll.dll
SBSFLT
ISAPI filters have been detected on the website Default Web Site. If they are not needed, please remove them. These filters may cause to not work properly.
Warning
Checking IIS directory paths IIS website Default Web Site root directory = c:\inetpub\wwwroot
Successful
Determining IIS website Default Web Site Internet address(es). IIS website Default Web Site server bindings = :80:
Successful
"AutodeskDM" virtual directory existence check
Successful
Check IIS connection time out. The IIS connection time out is :900.
Successful
Checking ASP Status Accessing a static file through the http protocol has passed. Test ASPX was able to successfully create a temporary file. ASP Status Check Web Service Call has passed.
Successful
Check permissions of the account used by ASP.NET.
Successful
Checking SQL version of Vault database instance.
Does not apply.
Checking SQL Server 'CADSERVER135\AUTODESKVAULT' The database instance "AUTODESKVAULT" was not found.
Successful
Checking site compatibility with the database
Does not apply.
Checking for existing Vaults with a remote FileStore
Does not apply.
Validating that this host name can be resolved on the local network Server hostname as known by DNS = CADSERVER135.
Server is resolved to following IP Addresses by the DNS:
192.168.1.244
169.254.13.177
Successful
Checking for known firewall
Does not apply.
Check administrative account creation.
Successful
Checking for a compatible Security Policy
Does not apply.
Exceptions
Title Message
Desperate, I tried to "continue" with the install as the filters are not there and it does say "may" affect. Still no bueno. "Error occured while installing" and the following log file message: (The last three tries)
2012/11/21:11:07:00 administrator CADSERVER === Setup started on CADSERVER by administrator ===
2012/11/21:11:07:00 administrator CADSERVER Launch
2012/11/21:11:07:04 administrator CADSERVER PageOpen InstallDotNetDialog
2012/11/21:11:07:04 administrator CADSERVER PageOpen LaunchDialog
2012/11/21:11:07:08 administrator CADSERVER PageOpen LicenseDialog
2012/11/21:11:07:10 administrator CADSERVER PageOpen ProductSelectionDialog2
2012/11/21:11:07:30 administrator CADSERVER PageOpen FullProgressDialog
2012/11/21:11:07:31 administrator CADSERVER Installing ADMS System Check: C:\Autodesk\Autodesk_Vault_Basic_Server_2013_English_Win_32-64bit\x86\en-us\edmprechecks\edmwrapper_win32.exe /qw /prechecks /c "COMMAND_GROUP=Precheck SQLPASSWORD="AutodeskVault@26200" DATADIR="C:\Program Files\Microsoft SQL Server" IISPORTNUMBER="80" IISWEBSITENAME="Default Web Site" ISUPGRADE="FALSE" UILANGFOLDER="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\_AI8F.tmp\en-us""
2012/11/21:11:08:14 administrator CADSERVER Install ADMS System Check Succeeded
2012/11/21:11:08:14 administrator CADSERVER Installing Microsoft SQL Server 2008 Express SP2 (AUTODESKVAULT): C:\Autodesk\Autodesk_Vault_Basic_Server_2013_English_Win_32-64bit\3rdParty\sql2008Express\setup.exe /q /ACTION=Install /FEATURES=SQL /INSTANCENAME=AutodeskVault /SQLSVCACCOUNT="NT AUTHORITY\Network Service" /SECURITYMODE=SQL /SQLSYSADMINACCOUNTS="NT AUTHORITY\Network Service" /AGTSVCACCOUNT="NT AUTHORITY\Network Service" /ERRORREPORTING=0 /HIDECONSOLE /INSTANCEDIR="C:\Program Files\Microsoft SQL Server\\" /INSTALLSQLDATADIR="C:\Program Files\Microsoft SQL Server\\" /SAPWD="AutodeskVault@26200"
2012/11/21:11:09:57 administrator CADSERVER Install Microsoft SQL Server 2008 Express SP2 (AUTODESKVAULT) Failed Installation aborted, Result=1603
2012/11/21:11:09:58 administrator CADSERVER PageOpen InstallCompleteDialog
2012/11/21:11:11:15 administrator CADSERVER === Setup ended ===
2012/11/21:11:12:47 administrator CADSERVER === Setup started on CADSERVER by administrator ===
2012/11/21:11:12:47 administrator CADSERVER Launch
2012/11/21:11:12:52 administrator CADSERVER === Setup ended ===
2012/11/21:11:12:49 administrator CADSERVER === Setup started on CADSERVER by administrator ===
2012/11/21:11:12:49 administrator CADSERVER Launch
2012/11/21:11:12:52 administrator CADSERVER PageOpen InstallDotNetDialog
2012/11/21:11:12:52 administrator CADSERVER PageOpen LaunchDialog
2012/11/21:11:12:56 administrator CADSERVER PageOpen LicenseDialog
2012/11/21:11:12:59 administrator CADSERVER PageOpen ProductSelectionDialog2
2012/11/21:11:15:25 administrator CADSERVER PageOpen FullProgressDialog
2012/11/21:11:15:25 administrator CADSERVER Installing ADMS System Check: C:\Autodesk\Autodesk_Vault_Basic_Server_2013_English_Win_32-64bit\x86\en-us\edmprechecks\edmwrapper_win32.exe /qw /prechecks /c "COMMAND_GROUP=Precheck SQLPASSWORD="afjkl" DATADIR="C:\Program Files\Microsoft SQL Server" IISPORTNUMBER="80" IISWEBSITENAME="Default Web Site" ISUPGRADE="FALSE" UILANGFOLDER="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\_AI1B0.tmp\en-us""
2012/11/21:11:20:57 administrator CADSERVER Install ADMS System Check Succeeded
2012/11/21:11:20:57 administrator CADSERVER Installing Microsoft SQL Server 2008 Express SP2 (AUTODESKVAULT): C:\Autodesk\Autodesk_Vault_Basic_Server_2013_English_Win_32-64bit\3rdParty\sql2008Express\setup.exe /q /ACTION=Install /FEATURES=SQL /INSTANCENAME=AutodeskVault /SQLSVCACCOUNT="NT AUTHORITY\Network Service" /SECURITYMODE=SQL /SQLSYSADMINACCOUNTS="NT AUTHORITY\Network Service" /AGTSVCACCOUNT="NT AUTHORITY\Network Service" /ERRORREPORTING=0 /HIDECONSOLE /INSTANCEDIR="C:\Program Files\Microsoft SQL Server\\" /INSTALLSQLDATADIR="C:\Program Files\Microsoft SQL Server\\" /SAPWD="asdjkl"
2012/11/21:11:21:51 administrator CADSERVER Install Microsoft SQL Server 2008 Express SP2 (AUTODESKVAULT) Failed Installation aborted, Result=1603
2012/11/21:11:47:50 administrator CADSERVER === Setup started on CADSERVER by administrator ===
2012/11/21:11:47:50 administrator CADSERVER Launch
2012/11/21:11:48:02 administrator CADSERVER === Setup ended ===
2012/11/21:11:54:23 administrator CADSERVER === Setup started on CADSERVER by administrator ===
2012/11/21:11:54:23 administrator CADSERVER Launch
2012/11/21:11:54:29 administrator CADSERVER === Setup ended ===
2012/11/21:11:54:26 administrator CADSERVER === Setup started on CADSERVER by administrator ===
2012/11/21:11:54:26 administrator CADSERVER Launch
2012/11/21:11:54:29 administrator CADSERVER PageOpen InstallDotNetDialog
2012/11/21:11:54:29 administrator CADSERVER PageOpen LaunchDialog
2012/11/21:11:54:32 administrator CADSERVER PageOpen LicenseDialog
2012/11/21:11:54:36 administrator CADSERVER PageOpen ProductSelectionDialog2
2012/11/21:11:54:53 administrator CADSERVER PageOpen FullProgressDialog
2012/11/21:11:54:53 administrator CADSERVER Installing ADMS System Check: C:\Autodesk\Autodesk_Vault_Basic_Server_2013_English_Win_32-64bit\x86\en-us\edmprechecks\edmwrapper_win32.exe /qw /prechecks /c "COMMAND_GROUP=Precheck SQLPASSWORD="AutodeskVault@26200" DATADIR="C:\Program Files\Microsoft SQL Server" IISPORTNUMBER="80" IISWEBSITENAME="Default Web Site" ISUPGRADE="FALSE" UILANGFOLDER="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\_AI89.tmp\en-us""
2012/11/21:12:07:00 administrator CADSERVER Install ADMS System Check Succeeded
2012/11/21:12:07:00 administrator CADSERVER Installing Microsoft SQL Server 2008 Express SP2 (AUTODESKVAULT): C:\Autodesk\Autodesk_Vault_Basic_Server_2013_English_Win_32-64bit\3rdParty\sql2008Express\setup.exe /q /ACTION=Install /FEATURES=SQL /INSTANCENAME=AutodeskVault /SQLSVCACCOUNT="NT AUTHORITY\Network Service" /SECURITYMODE=SQL /SQLSYSADMINACCOUNTS="NT AUTHORITY\Network Service" /AGTSVCACCOUNT="NT AUTHORITY\Network Service" /ERRORREPORTING=0 /HIDECONSOLE /INSTANCEDIR="C:\Program Files\Microsoft SQL Server\\" /INSTALLSQLDATADIR="C:\Program Files\Microsoft SQL Server\\" /SAPWD="AutodeskVault@26200"
2012/11/21:12:07:01 administrator CADSERVER Install Microsoft SQL Server 2008 Express SP2 (AUTODESKVAULT) Failed Installation aborted, Result=1603
I found that sometimes the 1603 error means the password is not complex enough, but I do not have password complexity turned on.
Any ideas? I'm at my wits end and I have to have this thing installed before the first week of December. Thank you for any and all help offered!
HI There,
1603 is a little generic but typically relates to security permissions. You could try installing SQL separately as per the WikiHelp instructions to get a better look at the error but also have a look at the following:
http://forums.autodesk.com/t5/Autodesk-Vault/1603-Error/td-p/3264344
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=13084251&linkID=9261340&siteID=123112
