Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Parts List
7 REPLIES 7
Message 1 of 8
tiger
504 Views, 7 Replies
Parts List
Working with Vault and Inventor bill of materials. The problem I'm having is with units of measure.
The default is set to Each for the units of measure. How can I change this to accept feet or inches?
Any help is appreciated.
Thank you,
Tiger
7 REPLIES 7
Message 2 of 8
cbenner
in reply to: tiger
Are you working in Inventor to create this BOM from an assembly?  Or are you creating this BOM in Vault's Item Master?  Can you post a screen shot of what you are trying to change?
Message 3 of 8
tiger
in reply to: cbenner
Yes, I'm working in Inventor creating from an assembly.
What I would like to do is convert an item/items from each to ft.
And do it so it will automatically make the updates.
Tiger
Message 4 of 8
cbenner
in reply to: tiger
Message 5 of 8
tiger
I've attached a PDF of my bill of material I'm working with.
Items 4, 5 & 7 should have a unit of measure in feet. These items
will change in different bill of materials.
How do I make the adjustment so when brought into my
BoM Inventor will distinguish the difference?
Hope I haven't confused you and Thanks for your help.
Tiger
Message 7 of 8
tiger
Tiger
Attached is Drawing8.pdf
Message 8 of 8
cbenner
in reply to: tiger
Are you using the attach button below?  Because there is still no file attached to your posts.
I suspect that you are looking at Unit Qty which is set to Each.  If your Base Unit is set to feet, then Base Qty will show the quantity as feet.  use the Choose Columns button in BOM editor and look at Base Unit and Base Qty.
