Working with Vault and Inventor bill of materials. The problem I'm having is with units of measure.
The default is set to Each for the units of measure. How can I change this to accept feet or inches?
Any help is appreciated.
Thank you,
Tiger
Are you working in Inventor to create this BOM from an assembly? Or are you creating this BOM in Vault's Item Master? Can you post a screen shot of what you are trying to change?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I still could use a screen shot so I can see what fields you are using in your BOM setup, that way I can tell you what to change and how.
Chris Benner
There is no attachment.....
Chris Benner
Are you using the attach button below? Because there is still no file attached to your posts.
I suspect that you are looking at Unit Qty which is set to Each. If your Base Unit is set to feet, then Base Qty will show the quantity as feet. use the Choose Columns button in BOM editor and look at Base Unit and Base Qty.
Chris Benner
