Apparently the update item works ok. It is when they do a change state from WIP to Released that they get this error on all items in the assembly.
They can go through each item individually and change state, then finally the change state of the assembly works.
As you can imagine, this can take them hours.
Happens on old and new jobs. Seems to have started since they migrated from 2011 to 2013 Vault Pro.
Update Item is what you need to use for this. You cannot modify an item, if the file it was generated from has had any changes made to it, without first updating. You can select multiple items at one time to update, such as a full assembly. Bear in mind two things, Items must be in WIP to update, and the more you do the longer it will take.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for this Chris,
That's what they are doing.
They take the top level item (assembly) and update that. Shouldn't this update all the children as well?
Once they've updated, they then get the error when trying to change back from WIP to released.
They then find that the only workflow left to them is to update and change state of each child item individually. Then they can finally work on the top level item. (Hours of work).
It seems as though the initial update of the top level item is not working as expected.
Dave
Updating the top level SHOULD update the children as well, yes. I'm not sure what you are running into. Can you describe the workflow of creating the Item? Is this Vault 2013? What level (Workgroups, Pro etc)
Chris Benner
Thanks for your reply Chris,
They're on Vault pro 2013 fully hot fixed and sp'd. The problem seemed to manifest iteself when they migrated from 2011 to 2013.
It looks like the update is not working properly, They have to update and change state on all the children first, then they can update & change state of the assembly. Although when you do an update of the top level item, it looks to go though fine with no duplicates etc.
I can't figure what's wrong here.
Dave
Have you had the chance to try this out on an assembly that was created after you upgraded to 2013, to see if that works correctly?
Chris Benner
Hi Chris,
It seems to be a problem post 2013 as well, but of course they may well be using old files in the new assemblies.
Dave
Ok,... I think we're getting above my "pay" grade. (not hard since they ain't paying me! )
I think I'm going to try to bump this one up for you, there is at least one guy i can think of that may have some thoughts... stand by.
Chris Benner
OK, it has been suggested that you log this issue as a tech support issue, so the development team can have a look at it.
http://usa.autodesk.com/support/
Are you a subscription customer?
Chris Benner
Hi.
We have exactly the same problem on some items. Did you find any solitions?
