Ok, this should be an easy one, but in my semi brain dead state this Monday morning, I'm not seeing it. Is there not some easy magical way to open an old version of a vaulted assembly? Mgt wants us to make some changes to a very large design, and be able to quickly chagne back if it isn't going to work. Copy Design is an option, but not a great one for something as massive as this. Getting an old version would be preferrable.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Do a get. In the Get/Check Out dialog; select and older version (drop down menu at the top of the dialog). Go to the local workspace; perform a cut or copy; place it in a non Vault workspace; right click the file and un check the "Read Only" box.
Thanks, I may have to try that.... but it looks like you can only grab Revisions, not versions. EDIT: Never mind... took a swig of coffee and looked with a clear sert of eyes... I got this.
Meanwhile the situation that led to this question has been resolved in another way.
Thanks.
Chris Benner
Hi guys,
On my side, I could not get the version on this way. the drop list shows me (Null):
Any settings to change this?
Bertrand as a Kid Blue
