Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Odd Vault checkout problem
1 REPLY 1
brendan.henderson
230 Views, 1 Reply
I finish an IDW, check it in, then do a SAVE AS the next drawing number. This has worked well for me since R8. But today when I do the SAVE AS for the new IDW number the previous IDW is shown in Vault Explorer as checked out. So then I open the previous checked out IDW and check it in again. I then do a SAVE AS to the next number and the check out pattern of the previous IDW continues.
This has only happened today, 3 days after a server upgrade (not the Vault server) occurred. Any ideas?
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
1 REPLY 1
luttena
in reply to: brendan.henderson
On the check in dialog, is the option checked to keep the file checked out?
If not, I would check the Vault options within the Inventor add-in. Take a look at your prompt settings for checking files out and see if it is set to 'silently' check out the file when it is modified.
Adam
Adam Luttenbacher
Sr User Experience Designer
Autodesk, Inc.
