My pleasure.
In regards to protecting the properties, the mapping that you would create
from this system property can only be a write property. That is to say that
it will never be read into the vault. That might help a little. Any time the
file is downloaded from Vault it will lay down the correct value.
Adam
"cadfish1" wrote in message news:6392439@discussion.autodesk.com...
I should have mentioned this before but my Vault Pro client is not connected
to the vault server because I'm having some difficulty installing 2011
therefore I can't get to any data so I flying blind at this point.
I do know how to point a Textbox in the title block definition to a file
property. I didn't know that these new vault system properties are mapped
to custom file properties in Inventor.
It dawned on me that any property available for edit in iProperties (tabs:
Summary, Project, Status, Custom) are modifiable in Inventor if the user is
not logged on to Vault. So someone could potentially change the values of
these new custom properties then make prints for manufacturing. I don't
care if these new vault system props are custom or standard props in
iProperties but it would be great if they could be protected somehow from
user changing from iProperties. In other words, only Vault can change them.
They would have to be in a list in Inventor "Format Text" dialog so the
admin could point towards this data in a title block but in any case if they
were protected against direct (iProperties) manipulation then it can be
considered to be a digital signature. This would allow us to go paperless!
This may not be workable because copying files becomes an issue because the
new file would contain digital signatures. Just thinking out loud.
Thanks for the help Adam.
