I'm not a current Vault user but lifetime Civil 3D. Currently, my firm is encountering some large projects where it would be useful to have multiple people working in the same drawing (or something similar).
Essentially we have large grading projects, with profiles, sections, etc. and it would be nice to be able to have one person be able to edit one alignment, grading, corridor, etc while another works on a different one within the same project, without complicated copy and paste operations.
So the question then, is this: Does Vault support this type of use with Civil 3D data? If it does, what type of equipment and software would we need to get it up and running?
Solved by AdamPeter. Go to Solution.
Vault Collaboration AEC does support Civil 3D object sharing across multiple offices. An overview of benefits can be found here. Depending on how it is deployed for replication hardware/software requirements vary. Follow this link to view, but I would recommend talking to your reseller to find out more.
Adam Peter (Autodesk)
