Vault General
CAD-One
Message 1 of 7 (324 Views)
Life Cycle Definition
324 Views, 6 Replies
10-06-2011 02:50 PM
I noticed that I cant delete a used lifecycle definition. I opt out the part/drawing to a None lifecycle but still cant find that we cant delete a life cycle definition.
I understand that somewhere high up in the history tab, an old version might have used that lifecycle. Is there a way to getrid of it? I dont want users to use it anymore.
Is there a solution?
C1
Inventor Professional 2013
Vault Collaboration 2013
Employee
mikel.martin
Message 2 of 7 (321 Views)
Re: Life Cycle Definition
10-06-2011 06:48 PM in reply to: CAD-One
You can not delete if a previous revision of a file used this Lifecycle.
However, you can remove it from all the categories and no user will be able to apply it to future files.
Mikel Martin
User Experience Architect
PLM / Data Management
CAD-One
Message 3 of 7 (319 Views)
10-06-2011 08:36 PM in reply to: mikel.martin
Mikel,
  1. I went to edit mode of the lifecycle definition. Right under the title I see a categories dropdown. Currebtly I had engineering selected. I unchecked that, applied, saved & exit. Is there any other place I should look?
  2. Also, now that this life cyle will not be available for use, for the files that are already in this cycle, Can I assign to opt out (None) & then change the life cycle to new one?
C1
Employee
mikel.martin
Message 4 of 7 (316 Views)
10-06-2011 08:56 PM in reply to: CAD-One
You can change what category a LC is assigned to with the workflow you describe or you can go to the Categories dialog and change it there. Both have the same result.
You dont have to change a file to None before switching it to another Lifecycle def.
You can change to any Lifecycle assigned to the files category. A category may have more than one lifecycle assigned.
You may change the Lifecycle that a file is assigned to in the Change State command.
Hope this helps.
Mikel Martin
CAD-One
Message 5 of 7 (312 Views)
10-06-2011 09:27 PM in reply to: mikel.martin
Thanks a lot
C1
scottmoyse
Message 6 of 7 (284 Views)
10-08-2011 01:52 PM in reply to: CAD-One
CAD-One you shoudl use the accept as solution if this has been resolved. It helps other people later on when searching the forums for solutions
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
CAD-One
Message 7 of 7 (280 Views)
10-08-2011 03:21 PM in reply to: CAD-One
Scott, thanks for prompting. :smileyhappy:
C1
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
