Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Job Queue: Sync Properties
11 REPLIES 11
Message 1 of 12
PVT_Stewie
548 Views, 11 Replies
A quick question; What causes Sync Properties error in the Job Queue?
Is there a quick way to resolve it?
11 REPLIES 11
Message 2 of 12
Cadmanto
in reply to: PVT_Stewie
Are you talking about this?
If so just select the file and go here.
If this is not what you are talking about, can you provide some images of what you are seeing?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 12
PVT_Stewie
in reply to: Cadmanto
No, I'm referring to Sync Properties errors that appear in the JOB Queue when files are set to "Release" state in Vault.
Message 4 of 12
Cadmanto
Ok, what causes the files to be out of sync is when a revision change occurs, the files need to be sync'd or updated.
That can be done like I explained in my last posting.
Best Regards,
Scott McFadden
Message 5 of 12
cbenner
Scott, I think he's trying to use the Job Processor... which you may not have in your Vault setup... I think it only comes with Pro... not sure.
My opinions of the JP are very low, I've never had it work correctly for me... so I quit using it altogether.  We're a small enough operation that we can sync properties and create dwf's manually as needed.
My best guess is that the operation is pegging out your processor.  Even though you may have multi cores, JP uses only one... and it often reaches max... and then the JP just gives up.  There are a lot of threads about this all over these forums... I don't know if any solution was ever found.
Message 6 of 12
PVT_Stewie
Scott,
the suggestion you made has already be done, but is not the error that shows up.  When we force that type of synch Vault deosn't find descrpencies.
What I'm trying to find out is if there's another way manually do the sync that is attempted automatically in Job Processor?
We are using Vault 2013 Pro.
Message 7 of 12
cbenner
The manual methid for sync properties is what Scott showed you above, select the file or files, go to Actions\Synchronize Properties.  I don't think there is any other wat than that or the Job Processor.
Message 8 of 12
Cadmanto
That would make sense.  I am only using workgroup.  I have never used JP so I cannot speak to it.
This is where posting images helps as well as stating up front what version of software you are using.  Smiley Happy
Best Regards,
Scott McFadden
Message 9 of 12
PVT_Stewie
Scott,
Yea, I have to remind myself to post what program I have......i keep forgetting to do that.....Smiley Frustrated
I tried posting a screen-shot but for some reason it won't attach.....any ideas on that one?
Message 10 of 12
Cadmanto
Not sure if you are trying to attach an image or post it.
If you have a .png or jpg or bmp file you can use this method.
Best Regards,
Scott McFadden
Message 11 of 12
PVT_Stewie
It worked....Smiley Very Happy  Thanks.
That being resolved, please see below.
Message 12 of 12
Cadmanto
Well, I am glad that little issue is resolved.
Like I said before I do not have vault pro, so I have no experience with what you are asking, but I did find this thread that might answer your question.
http://forums.autodesk.com/t5/Autodesk-Vault/Job-Processor-Error-Sync-properties-not-allowed-on-non-...
Best Regards,
Scott McFadden
