In vault 2014, there was a seperate sync properties event for each file type (e.g. autodesk.vault.syncproperties.iam, autodesk.vault.syncproperties.iam, etc.) but in Vault 2015, there is only 1 (autodesk.vault.syncproperties).
If you manually edit the JobProcessor.exe.config file and put an entry in so it handles the generic job (autodesk.vault.syncproperties.iam), it errors out with message "Job Param error".
Based on this, there doesn't seem to be a way to have a Job Processor 2014 do a property synchronization for a Vault 2015 server. This is not good 😞 As part of the commitment to "Forward Compatibility", is there a configuration setup I am missing or is this a bug/defect?
Ryan
Ryan,
Can you create a support case for this issue?
