Hi Vault users,
I get an error message when trying to update an item to show the "Approved" stamp .
I says: "Visualization file cannot be created fro this drawing due to vault restrictions.
The restriction says: Unknown error during publish.
Is it looking for a rendering file that is missing?
Frits van Lingen
What version of Vault is this? I've seen it several times in Vault Pro 2015 and have not been able to figure out what is causing it. The only fix I have found is to open the CAD file and check it back if from the CAD application, thus creating a new visualization file. I do not use Job Processor, so I'm not sure how that would factor in.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi
I am using Vault 2013. I cannot checkout drawings without creating an ECO, so that wuld be extremely difficult.I am gatting the error message with every item I am trying to update, not just one drawing in particular.
Sometimes, deleting the visualization file from the Project Explorer will clear whatever the error is on that file, allowing you to update. The fact that this is happening with all of your files tells me something else might be going on. You may want to escalate this to a tech support case.
Anyone else have any thoughts?
Chris Benner
