Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Item's BOM tab lacks revision
8 REPLIES 8
Message 1 of 9
Maxim-CADman77
695 Views, 8 Replies
Software used: Autodesk Vault Pro 2014 SP1 update 1
Problem:It is impossible to compare Item BOM revisions.
Vertical slider on General tab does have two positions (revision 0 and revision 1) and can be moved.
Vertical "Revision:" slider on BOM tab is fixed in upper position ("Latest").
Drop down list just above the slider also has the only value - "Latest"
Drop down list on BOM Item toolbar also has the only value - "Latest"
Question: What I'm doing wrong and how should I compare the revision "0" BOM vs revision "1" BOM?
Thanks in advance.
8 REPLIES 8
Message 2 of 9
mthomas
in reply to: Maxim-CADman77
You don't use the slider... open or edit the item, goto the Bill of Materials tab and along the toolbar you should see the Compare options where you can find the tools to compare BOM revisions
Mike Thomas
Message 3 of 9
Maxim-CADman77
in reply to: mthomas
Thank for the attempt.
Edit is definitely not the proper way...
Opening Item improves nothing - still have only "Latest" value in drop
down list you have outlined.
Message 4 of 9
cbenner
Compare appears to be a way to compare the BOM of two different Items.
On the original question, I am able to use the slider bar on an item that has multiple revisions, in the BOM tab.  I cannot compare side by side, but I can look at the BOM from each revision.
Message 5 of 9
Maxim-CADman77
in reply to: cbenner
"Compare appears to be a way to compare the BOM of two different Items."
Not exactly. See help - It is supposed to for two types of comparison:
BOMs of different Items and BOMs of two Item revisions.
I can't say that I'm all the time comparing Item BOMs but ... but I
remember doing this several times and ... and till this case It was
always possible (slider was movable and drop-down list was representing
several revisions).
Message 6 of 9
Week have passed since Vault tech-support opened the case for the issue but still no real help.
Users are annoyed...
Message 7 of 9
Three weeks since issue reported to tech-support. Still no real help :(.
Message 8 of 9
kolesaa
Hi All,
see help with Autodesk for Vault Bills of Materials (Rule#2)
Message 9 of 9
Maxim-CADman77
in reply to: kolesaa
Thanks a lot! Yes - indeed we were expecting the thing that is not declared (BOM of WIP revision). The user should have released the revision but haven't did it.
PS: Pay attention that issue was clarified without providing full dataset to Autodesk (that was "best offer" from tech-support).
