Hi, Does anyone know how to retrieve the items (records) associated with a change order through the API? I can access the change orders through the change order service, but there's no property (I expected an array) with the associated items. How can I find these?
Solved by paul.gunn. Go to Solution.
What release of vault are you using? In 2011 I believe you want GetChangeOrderGroupByChangeOrderId.
Paul
