All,
does anyone know what would cause a generic '100000' number to be assigned to an item? and
is there a way to get the correct number in there cleanly?
What version of Vault are you using?
Are you using a part numbering scheme?
What ERP system are you connected with?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Sorry,
I am using Vault 2013 Pro.
The numbering scheme is manually input.
We are not running an ERP through Vault.
No problem.
Sorry to say, but I can't help you. I am running vault workgroup 2012.
Don't know much about vault pro. We haven't upgraded yet.
That sounds like the default "sequential" numbering scheme. Creating an item will always default to this scheme. To change it, you have to create a new scheme. To assign an item number using the new scheme, you have to click on "Actions" at the top of the item window and choose "change item number". Hope that helps!
