Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Item Number Based on Filename
14 REPLIES 14
Message 1 of 15
932 Views, 14 Replies
How can I have the item number be based upon the filename?
I found a blog post about doing this using "Component Name"; problem is, the file extension is included for the Inventor filetypes (guess that's why it was demonstrated using a word doc)!
Steve
14 REPLIES 14
Message 2 of 15
I wrote the post - no trick! Promise 🙂
I just tried this again with ONLY the component name mapped to part
number... Extension is not included.
What version of software are you running?
Can you send a screen shot of your mappings?
Can you send a screen shot of your assign item dialog (like mine?)
Brian Roepke
Manager, Customer Success
Data Management
Autodesk, Inc.
"steveing" wrote in message news:5656367@discussion.autodesk.com...
Steve
Message 3 of 15
Wow, fast reply - thanks.
However, even with your suggestion it didn't work 😞
We are running Inventor 2008 and Productstrem 2008.
See attached screenshots.
Message 4 of 15
I'm stumpped - I tried a few different things to break mine and couldn't do
it... I even added a file via drag and drop which can mess lots up...
does this happen for every file? what about DWGs? Word Docs? Text files?
just looking for more clues.
Brian Roepke
Data Management
Autodesk, Inc.
"steveing" wrote in message news:5656386@discussion.autodesk.com...
Message 5 of 15
Brian,
The problem seems to be tied to the Inventor files; DOC, DWG, JPG, etc. seem fine.
I even tried this on a second test machine (adms and clients on same computer). This was a brand new vault; including knowledgevault and a user vault. The same problem 😞
I created a backup of the ADMS which I uploaded to here: http://download.yousendit.com/22DE3DD320DBAE80
Hopefully you have the opportunity to restore my backup onto your machine to try on your end.
Steve
Message 6 of 15
Steve
I was able to get this to work. I simply check the file out, saved it in
Inventor 2008 and then checked it back in (it was already in 2008 format but
it still wanted to save... I'm not sure why.
When I checked it back in it worked - no extension.
How are you adding these files to the Vault? (the Inventor files?) Drag and
drop?
Brian Roepke
Data Management
Autodesk, Inc.
"steveing" wrote in message news:5656440@discussion.autodesk.com...
Brian,
seem fine.
try on your end.
Steve
Message 7 of 15
I have it restored and I'm looking into it - one thing I would do is use
this project file instead - this will ensure if you use Autoloader in the
future that you'll be compatible - it's my #1 recommendation.
Also - don't add new library paths or modify anything. Just place
everything in a sub folder of one of these two (three if you count content
center files) paths.
Brian Roepke
Data Management
Autodesk, Inc.
Brian,
seem fine.
try on your end.
Steve
Message 8 of 15
Brian,
Thanks for your suggestion regarding Autoloader and folder names; definately something to consider.
In regards to the item numbering based on filename; where you able to restore the sample vault that I had sent to you and if so, what were the results of your testing?
Steve
Message 9 of 15
I posted this above - see the reply before the last - it worked fine... but
read the reply
Brian Roepke
Data Management
Autodesk, Inc.
"steveing" wrote in message news:5659032@discussion.autodesk.com...
Brian,
Steve
Message 10 of 15
Hello
Can you confirm whether it is possible to map the item number to the filename now in Vault Pro 2011 as I cannot find the field Component name any more.
I wish to map a the filename of a PDF as the item number
Message 11 of 15
mollons
Yes, it is possible.
You need to add an additional Initial Mapping to Component Name property.
See my attached screenshot.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 12 of 15
in reply to: mollons
Scott
Thanks for the advice.Filename is now mapping to the item number.
Message 13 of 15
chris_turner
Can you do this with a TIF file? I'm using VP 2012. I created a property called Component Name but can't seem to map to it. I would like to take a whole lot of legacy TIF files from an old system and put them in the Vault. If I could map the filename to Item that would be great - Or even if I add a custom vault property to the tif file and then map that to the Item.
Thanks in advance for any advice.
Message 14 of 15
mollons
in reply to: chris_turner
You should be able to map to the filename of the file and use it as the item number.
Other properties on a TIF file I am not sure about.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Message 15 of 15
mvigneau
Hello community !
Could I have more information about the extension that remains in the Item Number when the file is an .ipt ?
Is there a way to set a different behavior ?
