Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Item BOM doesn't update in VM 2010
5 REPLIES 5
MaxU77
538 Views, 5 Replies
Vault Manufacturing 2010 update 2.
Some time ago the Item was created for the particular IAM.
Later that IAM was redesigned quite a bit. Some top level components were demoted to sub-assies.
Item Update command had no desired effect on BOM (no effect to BOM at all).
I thought if all components were be removed from BOM - Vault would guess that something is wrong and finally will update it :-).
After repeating "Remove row" command the Item BOM is empty now but again update have no effect.
I don't want remove and create Item (I did it in the past - yes it helped, but I don't want - it is definitly wrong way). I want update to be working.
What might be wrong? What can i do?
Thanks in advance.
MaxU77,
AI2011 Certified Associate
(Soft: PDSU2012, VP2012&VP2013)
5 REPLIES 5
MaxU77
in reply to: MaxU77
Nobody suffer the problem except me?
MaxU77,
mollons
in reply to: MaxU77
Try removing the primary link to the assembly file from the item and reassigning item to the assembly file.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
MaxU77
in reply to: MaxU77
Too late for that particular Item - It stopped our work thus already removed. I'll try your recommendation when situation would repeat (I'm sure it would).
BTW, now we can't create that deleted Item because of Er1404...
MaxU77,
MaxU77
in reply to: MaxU77
Item BOM issues continue in Vault Pro 2012 upd1.
Items of some components occasioanlly "jump" to the assy-Item level while updating assy-Item and disappear from BOM Item as a result.
Tech support case is open but any informal help is welcome.
MaxU77,
Maxim-CADman77
in reply to: MaxU77
That same issue in VP2013 SP1!!!
Autodesk were are you with your ... support?!
